View Poll Results: 5-lug worth it?
Yes
141
38.32%
No
227
61.68%
Voters: 368. You may not vote on this poll
Is a 5-lug conversion worth it?
Old 11-23-2010, 08:14 AM
  #151
vtec youngter's Avatar
Default Re: Is a 5-lug conversion worth it?
what are the items needed for this swap
Old 11-23-2010, 12:23 PM
  #152
EHondaJDM's Avatar
A brain
Old 11-25-2010, 05:57 PM
  #153
collin-eg2's Avatar
Originally Posted by cannan
If your looking for OEM reliability and good stopping power, it can be achieved using OEM parts at a cost much less than that of the entire 5 lug conversion. This thread is full of worthless information and speculation.
How? Cutting up some other rotors on a lathe and using calipers from another car? Thats cool if you think that's legit. I don't
Old 11-25-2010, 07:57 PM
  #154
Information Leafblower
bluebomber's Avatar
There's actually a great deal of good information in this thread. If you can't be bothered to read any of it, I summarized everything for you in a post above. You're welcome.
Old 11-28-2010, 04:05 PM
  #155
cannan's Avatar
I read it through and yes your post was very informative, however it is one of few.
Old 11-28-2010, 04:24 PM
  #156
deeraw904's Avatar
who really cares if its worth it or not,its your car,do as you wish.at least this mod has a advantage to it.almost everyone try to make a faster car,but not even half will do any-type of brake upgrade.so consider this a 'fair cost' oem upgrade and not just some jdm candy.........
Old 11-28-2010, 06:02 PM
  #157
Circuit Star-29's Avatar
Value wise, NO...
You can simply install modified ITR calipers and modified VTEC prelude rotors and have nearly identical fade resistance. Step up to a 1" M.C. followed by a decent pad and stainless lines and you'll have better brake fade resistance and a better pedal feel with all of these components. Of course Fade resistance + Friction (pad & tire) = stopping distance.
Five lug also weighs 44 lbs more than the 4-lug so you're increasing unsprung weight. But for the cosmetic factor, yes. Its worth it.
Old 11-29-2010, 12:03 AM
  #158
ek9dc2's Avatar
just do what I did poor mans 5 lug conversion with the best looking wheel and brake combo. just my 2 cents
Old 11-29-2010, 12:15 PM
  #159
nonsense's Avatar
It's for looks not performance so if you like the look and you think it's worth it then yes it's worth it. I've never had a braking problem on the track with stock Integra brakes and good pads (it's the pads that will make the difference).
Old 06-20-2011, 11:52 PM
  #160
andrewxxcarlson's Avatar
Originally Posted by BMXman
if you want bigger brakes there are cheaper options out there...D
Old 06-22-2011, 12:45 PM
  #161
will_quach's Avatar
they're worth it imo. show factor, rarity, and the braking power is a huge difference from stock. most of the 5 luggers around my area are too lazy to piece together a setup similar and rather just bolt on the hubs/control arms/brakes all at one time.
it is probably a cheaper route to gather everything up but it's really up to the owner.
just my 2cents
Old 11-12-2013, 10:28 PM
  #162
r0bm2000's Avatar
I know this topic is dead but I keep finding topics like this when looking for 5 lug vs 4 topics and the funny thing people keep talking about his JDM BLING.....the people who call it JDM bling is the most dumb people ever......we did have a USDM TYPE R u know???? so how is that JDM BLING?? and the only difference was in the JDM one was the 36mm axle but then again the OLDer crv's came 36 mm and share and use the same setup as a JDM type r front..so i doubt its a "JDM BLING YO" ....also people keep saying the type r set up weighs more ....but when you add all this stuff to the 4 lug setup does it not add almost about the same weight??? unless you get the civic type r set up where i read that the civic rear disc was lighter
Old 11-13-2013, 03:12 AM
  #163
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
I like being able to go to any parts store to pick up parts if I need them. The re-drilled prelude rotors don't come that way...and neither do the modded brackets. If you crack a rotor at the track, hopefully you're prepared.
Besides that, the ITR did come with better wheel bearings. I'm sure someone has pointed out that there are very few 15" wheel options for 5 lug cars, however.
I really like the 5 lug setup....but it is a little unnecessary. I was able to get them cheap enough from a JDM distributor that it would have been more expensive to redrill rotors and buy calipers/re machine brackets. I think I got my 5 lug setup on my DB8 and the one on my EM1 for about $200 out of pocket. But I did already have a spare set of ITR wheels laying around. I've also found a 5 lug with CW CTR wheels at a junkyard for under $300. Why anyone would junk a car with a 5 lug (and a bunch of other really rare/expensive parts also) is beyond me.
As far as axles for the 36mm 5 lug, I know 100% for sure that 5G prelude base model driver side axles are 100% bolt on. The passenger side bolts on as well....but I found out that the surface that mates to the axle seal is too long. So I had to swap in B series axle INNER joints.
I have pics and info that I was gonna make a thread for. I think that 5th gen prelude SH axles would probably be a direct fit on the passenger side.
The CTR 5 lug is 32mm....but will require an alignment really bad unless you're putting it on a 96-00 civic.
The CRV 5 lug is a civic spindle....but with a 36mm hub.
The USDM ITR is 32mm and most likely stolen. The JDM ITR is 36mm...but you can use prelude axles.
Old 11-13-2013, 09:46 AM
  #164
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Originally Posted by PatrickGSR94
Nope, not worth it at all. You can easily get ITR-spec brakes while still retaining your 4x100 hubs for way less money than the full 5-lug swap.
This!!! I have Itr brakes on my 4 lug civic for less than $300. There was no modding my bracket or redrilling my rotors. I avoided having to shave my bracket by using Stock Mini Cooper rotors on my Integra Knuckles so I have the ability of going to the parts store if something does break. My hatch is a track *****.
Old 11-14-2013, 03:33 AM
  #165
B serious's Avatar
Yes...with mini cooper rotors, the 11.x" front brake conversion can be bolt on. I think you can use EP3 parts for the rear as well.
Again, the 5 lug does come with stronger hub bearings, but that might be the last real remaining advantage lol. They do look really good, however.
Dturcios96
12-16-2013 03:27 PM
ddtfrom626
05-10-2008 08:54 PM
Mr.Civic
06-19-2004 09:03 PM
YaMaJeSty
21
01-07-2004 09:01 AM
Civichatch2k
01-29-2003 06:46 PM
Quick Reply: Is a 5-lug conversion worth it?
