View Poll Results: 5-lug worth it?
Yes
141
38.32%
No
227
61.68%
Voters: 368. You may not vote on this poll
Is a 5-lug conversion worth it?
Old 07-07-2009, 04:11 AM
  #26
Daisy... Daisy...
Dogginator's Avatar
Default Re: Is a 5-lug conversion worth it?
Originally Posted by nsxtasy
Nope, the 5 lugs won't do anything for you.
As for bigger brakes (regardless of the number of lugs), keep in mind that no brakes will give you any greater stopping power than your tires can handle. If you want better stopping power on the street, the first step to take is to get better, stickier tires. A more aggressive pad compound would be the second step. And a higher temperature brake fluid is the third step to take. And none of these steps requires changing the calipers or rotors. Do all of these things, and you'll probably find that you don't need to change the calipers or rotors at all. Not for street use, anyway.
If you track your car, the big reason for big brakes is to manage the heat of the brakes, more so than for stopping power - IOW to prevent the brakes from getting too hot and cracking rotors too often. And even on the track, your best bet is to take other, less drastic measures first (e.g. pads designed for the racetrack), and only upgrade calipers/rotors if you're still having problems.
I thought you found the stock 262mm brakes on your GSR were inadequate for the repeated braking cycles of HPDEs.
Old 07-07-2009, 05:02 AM
  #27
PatrickGSR94's Avatar
Originally Posted by shwanC
The CTR/ITR brakes do weigh alot more than the factory brakes. With that little bit more meat, there is less brake fade, which no one has mentioned yet. Also, the fact that having a facotry brake setup lets you pick up aftermarker parts from most part stores.
A trip to autozone or napa for a rebuild kit for Wilwood 4-pot calipers would be a waste. Factory 98-spec ITR on the other hand...
I just can't get over people saying its just for looks. Wow.
Did you check the links I posted above? You can get ITR-spec brakes while still retaining your stock hubs for less money than a full 5-lug conversion.
As for wheel choice, I guarantee there are just as many choices in 4x100 as there are in 5x114.3. Wheel choice isn't really a valid justification for converting to 5-lug.
If you get a smoking price on it, and you know that the parts ARE NOT STOLEN, then by all means go for it. But in most cases, you can get the same braking power and have the same wheel choices for less money.
Old 07-07-2009, 05:11 AM
  #28
Daisy... Daisy...
Dogginator's Avatar
A car with a 5-lug swap is a greater target for theft.
Old 07-07-2009, 06:21 AM
  #29
H-T Order of Merit
nsxtasy's Avatar
They're perfectly fine for street use. And for the track, the stock brakes give adequate stopping power; just to repeat myself, the issue with track use is heat management, not stopping power (and heat management is not simply a matter of rotor size).
However, the OP has not mentioned any intention of using his car on the track. For street use - his apparent intention - there is no performance reason to get bigger brakes. Of course, you can still do it if your objective is for the bling bling.
Old 07-07-2009, 06:57 AM
  #30
If you just want the ITR-style wheels, there are also 4-lug ITR replicas out there.
Old 07-07-2009, 10:01 AM
  #31
deejaylewlew's Avatar
5 lug = pointless for the average dd
Old 07-07-2009, 12:27 PM
  #32
racebum's Avatar
Originally Posted by PatrickGSR94
Integra 11" kit $630: http://www.fastbrakes.com/ProductDet...DC+11+inch+kit
Or for $120 more you can go up to 12.2" rotors with 4-pot Wilwood calipers (requires 16" or larger wheels): http://www.fastbrakes.com/ProductDet...tegra+140+6163
the fastbrake kit can be done for less if you're resourceful
trade in gsr calipers for legend/itr caliper remans $120
axxis ultimate pads $75
mill calipers $40
prelude vtec blank rotors $80
$315 total which is half of what FB wants. drilling the rotors yourself isn't hard. you can even be a little sloppy since they are hub centric
Old 07-07-2009, 02:05 PM
  #33
maxogsr's Avatar
x2... I track my car for 5 years now on 4 studs and never, ever had issues of any kind... like nsxtasy said, it's all about tires, brake oil and pads... And remember, the later you brake on track, less heat you'll built... brake harder and later is the key...
Old 07-07-2009, 02:06 PM
  #34
Global Moderator
Jimmy's Avatar
Originally Posted by jhammond_82
i don't think so. stockers work just fine for me. and if you like to rotate your own tires, just think, thats another 4 lugnuts to loosen and tighten!
Originally Posted by dntnedvtec
LOL, especially if you do it by hand...
IMO, it opens up your world for a different selection of rims. (5-lug compared to 4-lugs.) I wouldn't get it though...to pricey. I also, nevermind. ShwanC beat me to it with weight.
I can't believe you guys are complaining about an extra lug on each wheel.
Lazy!
Old 07-07-2009, 07:56 PM
  #35
Rediness_code's Avatar
Not worth it, I love my 4 lug
Old 07-07-2009, 08:30 PM
  #36
dntnedvtec's Avatar
Lazy!
yeah, your probably right. But in my defense, my back hurts!!
Old 07-08-2009, 02:01 AM
  #37
R00teg's Avatar
Originally Posted by steveo135
rear control arms are different on itr's compared to all other integras (gsr\ls\gs) and by swapping the control arm for the conversion you would probably need new rear shocks
it's not worth it
/thread
you got it reverse man, if you utilize the ITR or CTR rear stock shocks/struts then you would need the ITR LCA. If not, then you would just bolt it on with your original LCA.
Old 07-10-2009, 05:28 AM
  #38
JDMsneakerz's Avatar
this info helps me too :D
Old 07-10-2009, 12:02 PM
  #39
vanny_david's Avatar
for $1000 just the 5-lug covnersion
also ITR has a total different suspension assembly than normal teg
I would spend those $$$$ to lighter wheels OR a nice set of 4 or 6-pot wilwood kit
Old 07-10-2009, 03:01 PM
  #40
keepinitrehaal's Avatar
Would you have to run 16" rims with this setup as well?
Old 07-10-2009, 09:14 PM
  #41
boostISbest's Avatar
/thread
x2
Old 07-10-2009, 09:27 PM
  #42
racebum's Avatar
no, but as i mentioned before you can do that kit for half the price
Old 07-10-2009, 09:28 PM
  #43
Bro. Darkness's Avatar
X2
Old 07-10-2009, 09:39 PM
  #44
hot_rice's Avatar
no HP gain!lol
  #45
V8 Eater's Avatar
I really like the looks of itr 4lugs from earlier itr's,I hate the itr 5lugs we and the jdm's have but the ones that are biggest in size with lots of spokes now that dope!
if the setup comes with rims and the rims I last mentioned I think its worth it,
your getting a nice pair of rims,
better brakes
better suspension
better wh-bearings
and if you ever get sick of it you can easily sell it since its one of those parts that dont loose much value!
I say go for it!
Old 07-23-2009, 05:07 PM
  #46
4doorteggy's Avatar
Originally Posted by NeverLift
i once thought of doing the conversion but i didnt want to anymore...why? because i dont track my car and it was just for looks. if you want to do it for looks then be my guess. for some, its a waste of money and for others, its worth it. function or fashion... you pick.
this
Old 07-24-2009, 06:10 AM
  #47
94DCLS's Avatar
Since i own a stock 95 dx and a 94 boosted integra ls, would it be worth it to put my integra breaks from all four corners on the civic and then go 5 lug?
Old 07-24-2009, 11:50 AM
  #48
Queensfinest88's Avatar
If i was gonna do some circuit racing YES for daily driving and an unmodified car NO!
Besides having ITR setup only increases the chances of peoples eyes on your car and waiting to scheme on you!
I wouldnt recommend it as much as i Love 5 Lug setups
Old 07-24-2009, 07:24 PM
  #49
Painfully Stupid
PaulMc's Avatar
The only people who are against 5-lug are the people who are to broke to afford it. ITR/CTR 5-lug is deffinitly worth it for all reasons function/form wise, and also just looks better.
Old 07-24-2009, 07:26 PM
  #50
Daisy... Daisy...
Dogginator's Avatar
I'm against it and can afford it many times over.
Quick Reply: Is a 5-lug conversion worth it?
