1994 acura integra idle fluctuating? - Honda-Tech
Old 07-27-2007, 01:28 PM   #1
94DC17's Avatar
Default 1994 acura integra idle fluctuating?
I need some help please.. I replaced the idle air control sensor and my idle still goes up and down from around 1500 to about 3000RPM's. I dont know what else it could be, some one told me it could be TPS or vacuum line but i dont know.. so please help me out.
thank you
94DC17 is offline   Reply With Quote
Old 07-27-2007, 01:54 PM   #2
* B A N N E D *
Default Re: 1994 acura integra idle fluctuating? (94DC17)
You have a vaccum leak or bad ground.
St Jimmy is offline   Reply With Quote
Old 07-27-2007, 01:55 PM   #3
LordAphotic's Avatar
did you recently replace the intake manifold ?
LordAphotic is offline   Reply With Quote
Old 07-27-2007, 02:08 PM   #4
94DC17's Avatar
Default Re: (LordAphotic)
I haven't replaced the intake manifold and what kind of ground would i be looking at?
Also how would i check for leaks?
thank you,
Old 07-27-2007, 02:55 PM   #5
hard charging 929's Avatar
Default Re: (94DC17)
air leaks from the throttle body or intake manifold gasket or any of the air lines running off the intake mani. wil cause a vacuum leak.
What year is your car and have you reset your ecu lately. If you have or if your battery went dead or I believe just over time you need to adjust your idle. If you idle is set too high it will cause a surge. You can try to lower it down and see what it does. There's a screw on the throttle body, use a flat blade screwdriver and turn it. You'll hear the engines rpm's lowering or rising, try and lower it down to I wanna say stock is 750 rpm +/-50 rpms. See if it's a simple idle adjustment or if it's something else. Also, you want to check your fast idle valve. Look in some of the FAQ threads for write ups and more info.
Hope it helps
hard charging 929 is offline   Reply With Quote
Old 07-27-2007, 04:01 PM   #6
94DC17's Avatar
Default Re: (agoldenau)
I checked most of the gaskets and they weren't leaking. I also checked all the lines to see if they were plugged in and they were. I'm reseting the ECU to see if that will do anything.
Old 07-27-2007, 05:37 PM   #7
94DC17's Avatar
i took off my fast idle control valve and i don't know if it is supposed to move around in there can anyone let me know thanks..
Old 07-28-2007, 12:02 PM   #8
1990 civic ef with idle problems GreenGoblinEF Honda CRX / EF Civic (1988 - 1991) 11 09-28-2014 10:04 AM
1990 integra GS idle and check engine light problems problems tunerboy90 Acura Integra 4 07-29-2008 08:46 PM
How do you adjust idle on carb? 86gasaver1500 Classic Hondas 5 06-04-2008 06:54 AM
some please help?!?!?!?!?!?!?!?! crfr230 Honda Prelude 3 04-24-2007 08:48 PM
Idle funny NoPaiNT Honda Accord (1990 - 2002) 3 11-02-2004 01:39 PM
Tags
1994, 1998, 94, 95, acura, adjust, adjustment, air, ajustment, controller, fluctuating, idle, integra, jimmy, st, surges
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
