1990-1993 Integra automatic to manual transmission conversion
Old 04-16-2012, 06:51 PM
  #51
Rushintegra's Avatar
Default Re: 1990-1993 Integra automatic to manual transmission conversion
What year are you workin on?
Old 08-21-2012, 08:31 PM
  #52
blkda9123's Avatar
Hey I'm about to do this swap this weekend on the 24th but I've got a few questions. I've got a 90 donor car to convert a 93 to a manual but I was wondering if the ecu from the 90 will work in the 93? I'm doing this to my daily/only mode of transportation so I don't want to do the swap then be left without a running car because of the ecu not working, that would be bad real bad. Please get back to me ASAP! Thanks!
Old 08-26-2012, 06:23 PM
  #53
blkda9123's Avatar
Icon3 Re: 1990-1993 Integra automatic to manual transmission conversion
NEED HELP ASAP! I'm wiring my green and green/black wires together but theres two green/black wires one with a red paint dot and one with a white paint dot. Which wire do I wire to the green?! One with the red paint dot or the white paint dot??
Old 08-27-2012, 12:05 PM
  #54
vallejoda9's Avatar
You would need to get a 93 Ecu. 90 is obd0 and 93 is obd1
Old 12-16-2012, 09:03 AM
  #55
CN7357's Avatar
So I just did my swap in my 90 integra and its all good but I can't get the key to come out of the ignition. Any ideas on how to get it out of the ignition switch?
Old 01-13-2013, 11:55 PM
  #56
pnwjdm's Avatar
i know this thread is old but its the only thread about this topic. so can some one help me? im planning to do this conversion but on the part where he took out the auto shifter im confused. the exhaust was running under it but then in the next pic he had his shifter and linkage right where the exhaust was. if i were to do the swap, would i need a different exhaust?
Old 01-15-2013, 08:56 AM
  #57
Bl6da9's Avatar
Stock exhaust will work, you'll just need to first remove the automatic shifter mechanism from the car.
Old 01-22-2013, 04:33 PM
  #58
B16da9 is right the linking will be above the exhaust after it is all put back together
Old 01-24-2013, 12:08 AM
  #59
Chaulkie's Avatar
Is it adviseable to remove the thermostart of my 2005 Honda accord Ex in a country like mine with a temparature of up to 45 degrees celsius? Is the really
Old 02-07-2013, 09:05 PM
  #60
Rodney Williams's Avatar
if i whould ever get a auto do u thank a junk yard whuld trade a working auto for a 5 speed manual
Old 03-01-2013, 08:18 AM
  #61
REDIntegra1990's Avatar
I did the conversion to my 1990 Acura Integra it worked thanks for the info it really helped
Old 03-01-2013, 08:38 AM
  #62
will the auto half shaft work on the 5 speed transmission
Old 03-07-2013, 05:43 PM
  #63
Hughie1987's Avatar
Im planning on doing this swap to my 90 GS it has cruise control also, I was wondering if I actually need to splice wires or if i could just get a different part of wiring harness or something?
Old 03-08-2013, 12:17 PM
  #64
i jumped the wires to make it think its in park it will start but it wont let the key out i have to remove the battery cable to get it out.do you know what it could be?
Old 06-25-2014, 09:35 AM
  #65
Hughie1987's Avatar
bump
Old 10-24-2014, 06:06 PM
  #66
BluDa's Avatar
connect the yellow wire from the transmission switch to the yellow wire in the 12 pin connector.
connect the green wire from the switch to the green/black wire in the 12 pin connector.
im swapping a b16a(jdm) engine
so the yellow and green wires are on the tranny? so i connect them straight from the tranny to the 12 pin connectors? my wires are green and green/black s80 hydro trans
and how do i install the vss since its a 3 pin connector instead of the one connector to the cluster
all i need is the stock b18a (automatic) wiring harness and the stock ecu?
Old 04-22-2019, 10:56 AM
  #67
Bpretty28's Avatar
Also for cruise control run 2 wires from ponk and black wires from switch on pedals and run them 2 the 12 pin connector were old automatic shifter was the wire are pink and black splice them together now cruise control will work plus instead of wireing the 2 thick black wires together to start car run 2 wire to clutch pedal interlock switch above cruise control switch and wire those 2 wires to the fat black wires doesnt matter which way it just sends power connecting two wire together when you push pedal down
Old 07-02-2019, 04:42 PM
  #68
dstappity's Avatar
is there a junkyard solution for cable to hydraulic clutch conversion? without having to spend 300 on aftermarket stuff?
HondaMechanic24
12-14-2012 12:42 PM
NAIIAWAH
07-02-2006 07:16 PM
Quick Reply: 1990-1993 Integra automatic to manual transmission conversion
