1990-1993 Integra automatic to manual transmission conversion
Old 02-11-2009, 04:07 AM
  #26
Bl6da9's Avatar
Default Re: 1990-1993 Integra automatic to manual transmission conversion
If you have any more questions feel free to AIM me @ bl6da9. If i don't awnser you right away it's probably because I'm in a meetting or with the wife.
Old 02-11-2009, 12:57 PM
  #27
teggything's Avatar
im never on there. thats all the ?s i have as of now but once i get everything out and start putting the new **** in i might have more thank you for ur help
Old 02-12-2009, 05:13 PM
  #28
TeggyKid952's Avatar
ok, i want to do this swap when i get the money, i already got the parts list from this
i have a 92 GS integra but mine is a DB (4-door)
what problems will this create? or will it not be any different?
Old 02-12-2009, 10:06 PM
  #29
teggything's Avatar
it will be the same im pretty sure the front of the car are the same its the backs that are different
Old 03-29-2009, 03:59 PM
  #30
teggything's Avatar
does anyone know it the automatic transmission speedometer cable will work from a 90 DA on a ys1 transmission?
Old 04-25-2009, 10:02 PM
  #31
teggything's Avatar
ok so i have a question i have cruise compatable pedals for my swap and everything i need. now when wiring my car how doi wire the clutch switch in so the 2 step on my ecu will work, and can i use the plug off my auto pedals for the manual pedals or are they different and i need to get the pigtail from 5 spd car??
Old 05-03-2009, 01:09 PM
  #32
New User
mike101's Avatar
wanted to know if u salen the shifter for a 90-93 acura integra if yes give me a call 6313792024
Old 05-25-2009, 05:08 PM
  #33
teggything's Avatar
how can i tell if its a manual one or automatic??
Old 05-25-2009, 05:09 PM
  #34
teggything's Avatar
i have my auto one out and the one thats supposed to b a manual but they look the same
Old 05-31-2009, 09:10 PM
  #35
SOHC_4dr's Avatar
i wanna do a auto to manual swap to put in a B18C1 into a 92 GS. will this write be the same in doing this swap? also what mounts should i use for this swap? what axles?
Old 02-19-2010, 06:19 PM
  #36
spyder_099's Avatar
so if im swapping to manual and using a ECU from a manual car(cause im swapping to B17 at the same time) i dont have any wiring to do at all?
Old 09-27-2010, 04:34 AM
  #37
freon480crx90's Avatar
i always find it necessary to ground out the green with white wire from the 12 pin plug as well in order to get the key out.
Old 04-04-2011, 04:57 PM
  #38
KtHaNxBai's Avatar
So do you need to solder both black wires together to get the reverse light to work?? Or will it work without that step?
Old 04-04-2011, 05:32 PM
  #39
tamparican's Avatar
nice write up, needing to convert y 94 teg to 5spd.. although might be a bit different, should be close to it?!
Old 09-08-2011, 02:45 AM
  #40
1stGenAcura's Avatar
Where can I get all the parts needed for a transmission swap on a 90 integra gs?
Old 10-04-2011, 03:00 AM
  #41
takin8ez's Avatar
bump for a quick question, I connected the two black/white wires near the console so the car will think its in park, but it still doesn't say its in park. Anyone have any suggestions?
Old 11-02-2011, 09:47 PM
  #42
elmalouno's Avatar
its not really tricking the system to think its in park, its basically just tricking the interlock so that u can remove the key. get yourself a manual cluster and forget all about it.
Old 11-03-2011, 02:44 AM
  #43
takin8ez's Avatar
Thanks, I got it all figured out I just bolted up the trans and was also wondering about those two solenoid plugs for the auto tranny. Just leave em' hangin? I'm assuming the manual ecu won't be looking for those
Old 02-11-2012, 08:32 AM
  #44
Rushintegra's Avatar
Icon2 Re: 1990-1993 Integra automatic to manual transmission conversion
Is the speedo cable the same or do you need a manual one
Old 02-11-2012, 08:38 AM
  #45
I would leave them hangin or tied up mad tapped up to keep water out of them just as a safety measure. Lol
Old 02-13-2012, 05:41 PM
  #46
fixin to do the swap this week cant wait to get done
Old 02-25-2012, 08:54 PM
  #47
Awsome post and a fairly easy swap. But I ran into a couple of things that I thought should be mentioned. 1 after you solder the two big black and white wires you will also on a 90 integra ls, solder the the green and yellow and the green and green and black wires in the 12 pin connector next two the wires you did first and also found it nessary to remove the 2 pieces of ac and heat ducking above the steering column to be able to drill the 1 3/4 hole for the clutch cable. Hope this is helpful and thanks again
Old 04-05-2012, 10:34 AM
  #48
vallejoda9's Avatar
How would you wire up a manual cluster?
Old 04-06-2012, 05:16 PM
  #49
Plug and play bro. No wiring needed
Old 04-15-2012, 01:18 PM
  #50
TravG's Avatar
Im currently doing the swap on my friends car he's has the gs model with the S mode for sport . i connected the big black/blackwhite together and the greenyellow/greenblack together and i still can't the key out am i doing something wrong? cause i see two green and black wires and neither seem to work.
Quick Reply: 1990-1993 Integra automatic to manual transmission conversion
