01 Integra GSR Crankshaft Position Sensor
Hello every one! I have 1 question from what I heard around where I live..
i recently bought a 2001 Acura Integra GSR.. The car cranks, but doesn't start. I have checked everything even the firing order and the cam shaft sensor and I get no spark.. So I believe I might have a bad Crankshaft Position Sensor. I heard that the D Series fits the B series, can anyone verify if this is true????
Re: 01 Integra GSR Crankshaft Position Sensor
I'd do some more troubleshooting before you go buying parts. Unless I'm missing something, a bad crankshaft sensor will not cause a no-start. You need compression, gas and a properly timed spark to fire up.
You say you get no spark, so there lies your problem.
Old Fart
Ditto the above, check coil and ICM, [igniter] first, far more common for a coil or igniter to go out then a sensor, there are simple test for both. 94
